Measurement Studio for VC++
barcode vision 2015
hi all
   i have a problem for coding to read 1D barcode.
the visual studio error is:
        error LNK2019: 无法解析的外部符号 __imp__imaqReadBarcode2@28,该符号在函数 "protected: virtual int __thiscall COCRFunctionDlg::OnInitDialog(void)" (?OnInitDialog@COCRFunctionDlg@@MAEHXZ) 中被引用
1>E:\VS2010\OCRFunction\Debug\OCRFunction.exe : fatal error LNK1120: 1 个无法解析的外部命令
when my use other function (pattern match or match sharp)not this error, but imaqReadBarcode2 or imaqReadBarcode3 have this error , imaqReadBarcode function have no error
.h file :
      #include "nimachinevision.h"
#include "niocr.h"
#include "nivision.h"
#include "io.h"
#pragma comment(lib,"nivision.lib")
have comment  library
please  help  very thanks
(5,552 Views)
i think the command--"#pragma comment" doesn't work in labwindows. i got the same type error with you.so i copy the lib to my project folder and the error is gone.
(4,544 Views)
Please refer to the following link regarding with your question:
http://ae.natinst.com/public.nsf/web/searchinternal/36f561f57095cadb86257cc4006c275b?OpenDocument
(4,517 Views)
the ni sw engineer have compile a new vision nivision.lib to me, it a bug in lib.
(3,811 Views)
so if you have this concern you can connect ni engineer
(3,808 Views)
