Measurement Studio for VC++
c#
Hi all
I am writing a program in visual basic C# to control stepper motors through the NI6211. The stepper motors are connected to a control card. And the control card is connected to a 74HC595 which is then connected to the 6211. I was wondering if I could get some help with the program to declare my 4 outputs of the 6211. Do I need 4 writers, 4 channels and 4 tasks? My code so far can be seen below:
            Cursor.Current = Cursors.WaitCursor;
            try
                using (Task digitalWriteTask = new Task())
                    //  Create an Digital Output channel and name it
                    digitalWriteTask.DOChannels.CreateChannel("Dev1/Port1/line0", "DataPin",
                        ChannelLineGrouping.OneChannelForEachLine);
                    digitalWriteTask.DOChannels.CreateChannel("Dev1/Port1/line1", "ParallelClock",
                    digitalWriteTask.DOChannels.CreateChannel("Dev1/Port1/line2", "SerialClock",
                    digitalWriteTask.DOChannels.CreateChannel("Dev1/Port1/line3", "Strobe",
                    //  Write digital port data
                    DigitalSingleChannelWriter DataPin = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
                    DigitalSingleChannelWriter SerialClock = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
                    DigitalSingleChannelWriter ParallelClock = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
                    DigitalSingleChannelWriter Strobe = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
                    SerialClock.WriteSingleSampleSingleLine(true, false);
                    ParallelClock.WriteSingleSampleSingleLine(true, false);
                    for (int i = 0; i < 8; i++)
                        if (motor_state & 0x80)
                            DataPin.WriteSingleSampleSingleLine(true, true);
                        else
                            DataPin.WriteSingleSampleSingleLine(true, false);
                        motor_state <<= 1;
                        SerialClock.WriteSingleSampleSingleLine(true, true);
                    ParallelClock.WriteSingleSampleSingleLine(true, true);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
            finally
                Cursor.Current = Cursors.Default;
(6,165 Views)
Visual Express, not visual basic! sorry
(6,163 Views)
And you have posted in the VC++ forum.
(6,092 Views)
