Measurement Studio for VC++
cwui error. How to recover?
Has anyone gotten this error? I'm working on a dialog based application which I created with Measurement Studio. Recently I reformated my computer and reinstalled everything once agian as it was before the reformating. I have visual studio 6.0 service pack 6. So I installed visual stuido and measurement studio, but whenever I try to open the project in visual studio I get the following error: Header of the message box is "cwui" and the description is "Error loading control. A newer version is needed. The default settings for the control will be used." I tried opening the same project on another computer which has the same setup, and it opens just fine. Did I forget to install something after reformatting? Any help would be really appreciated.
Thanks.
(3,586 Views)
This error occurs when you run a program on a machine that has an older control than what the program was built against.
What version of Measurement Studio do you have a license for? If you have Measurement Studio 6.0 or later, you should download and install the latest Measurement Studio controls. You can download the installer here.
(3,581 Views)
That did the trick. Just and FYI, the update file that you provided the link for me to download was already on the installation CD of Measurement Studio.
Thanks for the help. You saved me from a headache.
(3,567 Views)
