Measurement Studio for VC++
draw rectangle in plot
How can i draw rectangle in graph
with Component works++?
(3,356 Views)
Annotations were introduced to the C++/ActiveX graph in Measurement Studio 6.0. This is the best way to draw a rectangle.
Details:
CNiAnnotation::Shape is a property of type CNiShape. CNiShape::Type is an enumeration, one value of which is CNiShape::Rectangle. Use CNiShape::XCoordinates and CNiShape::YCoordinates to specify the location and size of the rectangle. Use CNiAnnotation::CoordinateType to specify whether the coordinates of the rectangle are in axis units or in pixels relative to plot area or screen area.
If you cannot upgrade to Measurement Studio 6.0, you could consider using 2 cursors as a workaround.
David Rohacek
(3,356 Views)
