Measurement Studio for VC++
elements in a matrix
I have a matrix A=[2 1 -1;-1 5 -2;-2 -4 -5;1 2 3], and I would like to determine the every element in A. If the element is
greater or equal to zero, I will change the element to 1. Otherwise, the element is changed by -1. In other words, the new matrix should be B=[1 1 -1;-1 1 -1;-1 -1 -1;1 1 1] based on the rules before. Does anyone help me?
POPo
(6,702 Views)
Hi PoPo, I assume you want to know for C++, since you've posted on the Measurement Studio Visual C++ board.  This code should do the trick:
myArray = {{2, 1, -1}, {-1, 5, -2}, {-2, -4, -5} {1, 2, 3} }; m=4; n=3; for (int i = 0; i <m; i++) { for (int j = 0; j<n; j++) if (myArray[i][j] >= 0) myArray[i][j] = 1; else myArray[i][j] = -1; } }
For general/non-NI programming questions like this, there are extensive amounts of information on the internet. A Google search for "2D Array C++"is a great place to start.
Mark E.
(6,669 Views)
Hi Mark,
   Thank you for your information. However, I would like to implement this idea in LabVIEW. How can I change the elements in a matrix,especially the size of matrix is big?
Thank you,
POPO
(6,665 Views)
Hi POPO,
You'll want to post your LabVIEW questions on the LabVIEW forums for effective support.  That way it will also be found most easily by other LabVIEW users.  This is the forum for Measurement Studio for VC++. You can find the LabVIEW forum at http://forums.ni.com
Mark E.
(6,631 Views)
