Measurement Studio for VC++
error when using example code
Hi all,
im trying to create a program for communication over a LAN network with a spectrum analyser.
when i use a standard example code i get errors like this one:
[Linker error] undefined reference to `viOpenDefaultRM@4'
did i made a fault in linking?
Message 1 of 8
(8,358 Views)
some more information:
i try to make a connection with a spectrum analyser from R&S (FSL)
i cant see the device with NI SPY, but dont know how to do that..
if you have a question, ask, i will answer
Message 2 of 8
(8,351 Views)
Ok.
I've managed to get further, using this example: http://www.rohde-schwarz.com/www/rs_sc.nsf/faq/FSPxAnalyzerre.html
problem is, this is Visual Basic in Excel, and I would really like to use it in the language C in another enviroment.
does anyone have any tips?
Message 3 of 8
(8,340 Views)
Can you please be a bit more clear on what you like to do? You like to use NI-VISA in Measurement Studio? Which Compiler / Language are you using?
Karsten
Message 4 of 8
(8,336 Views)
well, I dont know with program to use, I tried DEV C++ because its a free program i used to work with, but i guess that one doesn't work.
right now the connection is ok, problem is, i use the microsoft excel program, using macro's in the visual basic language.
what i want is to get the connection up and running in a program where i can program in the C language.
Message 5 of 8
(8,332 Views)
DAV C++ uses a GCC based compiler. The VISA DLL is compiled with MSVC. This will cause a problem with the calling convertions used and expected.
Basiclly the visa DLL uses 'viOpenDefaultRM' but the GCC expects viOpenDefaultRM@4, and thus can't find it in the DLL. You can solve this manually.
The basic steps are:
1. Generate a .def file from the DLL for example with pexports.
2. correct the .def file so all the functions have the correct decorations as expected by GCC.
3. Create a new import library,
For more infomation see this post about the same issue with NI-DAQmx
An other option would be to use the Visual Studio 2005 express editions?
And in some configuration you will need to buy a license to use NI-VISA: http://www.ni.com/visa/license.htm
Hope this helps
Karsten
Message 6 of 8
(8,326 Views)
I've decided to work with Visual Studio 2005 express editions, because that's a lot easier, I thought.
I have a problem when I want to add a reference to the VISA.dll file, I get the following error:
A reference to 'VISA library' could not register the ActiveX type library 'C:\WINDOWS\system32\visa32.dll'
Message 7 of 8
(8,311 Views)
When Using the Visual Studio Express editions I would advise to use the Native .Net support of NI-VISA.
When you Install NI-VISA make sure that you install support for the .Net Framework 2.0. When this is installed you should be able to add the "NationalInstrumts VisaNS" namespace to your program.
You can find the documentation trough Start -> Programs -> National Instruments -> VISA -> Documantation -> NI-VISA .Net Framework 2.0 Help.
Karsten
Message 8 of 8
(8,302 Views)
