Measurement Studio for VC++
graphcursors.fp not found after installation and library options setup in Meas.Studio 6.
After setting up Measurement Studio 6.0 and browsing for function panels of the instrument libraries in the toolslib\custctrl directory, I found the graphcursors.fp After installation and restart, the related library file is reprotedly missing from the system, and LabWin can not load it.
What is happening?Where can I find the library file?
By the way, during setup, when out of curiosity I asked the installer to to setup the visual C++ components, it reported that I have Visual C++ open and active, and refused to proceed with insgtallation. In fact, I newer installed Visual C++ on my system, it is a clean and fresh setup,with "virgin" HD.
Thanks in advance.
Lajos
(3,375 Views)
Answer posted here
Bilal Durrani
NI
Bilal Durrani
NI
(3,375 Views)
The message you saw while installing the Measurement Studio libraries for Visual C++ is strange. The libraries, add-in, and wizard require Visual C++ 6.0 with at least Service Pack 3, so you'll need to install that before you can install.
- Elton
(3,375 Views)
