Measurement Studio for VC++
help needed using NiReport in MSVC (using C, not C++/MeasStudio)
Hi, folks!
I develop my apps writing in C, using MSVC (not Measurement Studio/C++). I use LabWindows to design the UI and use the external compiler support to generate the UI's object file, which I link into my program. I've had great results doing this; I link to the appropriate .lib and the corresponding .dll is in the apps root folder.
However, I'm unable to get this to work for using the NiReport library. I'm trying to build the nirsample app which came with my LabWindows installation but the link step fails because it cannot find the exported functions required (NI_Report_xxx).
There is a utility that comes with the MSVC installation called Depends, which allows one to view the imported and exported fuinctions in a .dll file. When I load up the NiReports.dll, it only exports four functions: DllCanUnloadNow, DllGetClassObject, DllRegisterServer and DllUnregisterServer. Where are all the NI_Report_xxx functions? I think if I can find the proper .dll, I'll be successful in building my app and will be able to go on with my life...
Thanks in advance for any help.
'til next we type...
HAVE FUN!! -- Jesse
Message 1 of 1
(5,699 Views)
