Measurement Studio for VC++
how can I use ImageToArray function in Borland C++?
In C language a can't write
MyArray = CWIMAQViewer1->Image->ImageToArray
because I need to indicate the element of array for Assign the value.
I can not  assign a entire array as in Visual Basic
Sorry my english is very bad!!!
(3,095 Views)
It looks like you are trying to use the VB syntax in C, which as you have seen will not work.  I have attached part of an example program from our website.  This uses the image to array function in C.  I think this will help get you started.
Ryan M.
(3,081 Views)
