Measurement Studio for VC++
how to compile C language code on 64-bits windows to .so file and then load it in NI Linux Real-Time OS (ARMv7-A) ?
Please help, I want to compile the C language code generated by the matlab model into a dynamic shared library .so file under a 64-bit windows system, and then use the Labview real time module to call and run it on NI Linux Real-Time OS (ARMv7-A) , please tell me how to operate it. I have never learned about embedded. What compiler should I install and how to compile it? Is there anyone who can guide me with the steps? This problem has been bothering me for three weeks
(1,170 Views)
求助大神,我想在64位windows系统下将matlab 模型生成的C语言代码编译成动态共享库.so文件,然后用Labview real time 模块调用并在NI Linux Real-Time OS(ARMv7-A)上运行,请问该怎么操作啊,没学过嵌入式,应该安装什么编译器怎么编译呀,有大神可以指导下操作步骤吗?这个问题已经困扰我三周了
(1,130 Views)
Look here: https://nilrt-docs.ni.com/cross_compile/cross_compile_index.html
Rolf Kalbermatter  My Blog
(1,109 Views)
