Measurement Studio for VC++
how to get exe name of installed programs in uninstall path of registry
(9,143 Views)
Hello Zidz,
Could you give me some more information about what you are trying to do? Are you trying to get a list of the programs installed on the computer? I do not understand what you mean by "in uninstall path of registry", please explain so I can assist you further.
With warm regards,
David D.
(9,126 Views)
hi David, thnx for ur reply... n ya i want to get details of installed programs that appear in add/remove programs of the system.
i found that all those are listed under HKLM\Software\microsoft\windows\currentversion\uninstall path in registry. this is what i
meant by uninstall. but, in this, i get only install location and not the exact exe name of the softwares installed. do u have any idea on this.
And also, is there any way as to identify whether the installed program is application or server program?
Message Edited by zidz on 09-02-2008 11:57 PM
(9,117 Views)
Hello Zidz,
I am betting that the Windows SDK would be useful here. It's also possible that you could use C++ to search file names for .exe extensions in those folders. Measurement Studio does not add this functionality to C++, a great resource for the C++ side of things is MSDN or a number of other places.
With warm regards,
David D.
(9,097 Views)
hi David, thanks for your reply. i will try out as you said in SDKs approach.
(9,088 Views)
