Measurement Studio for VC++
how to reduce reading and recording data time/ Visual C++, PCI 6024E and PCI-MIO-16E?
Right now I am working on a data communication programme. The time of reading digital signal and recording data is more than I expected, which is about 100 microsecond. I need to reduce the time. The software I am using is Visual C++ 6.0. I use two DAQ boards, which are PCI-6024E and PCI-MIO-16E. I have set the priority of Visual C++ to be realtime by task manager. The operating systme is Windows XP.
I am wondering how to set the interrupt of reading or writing data to be the highest and stop any other kind of interrupt.
Thanks in advance!
(3,315 Views)
The primary limitation you will encounter when trying to do high speed digital I/O using your E-Series hardware is that the digital lines are all software timed.  This means that for each and every digital read it is necessary for your software to issue a command to your hardware, read a single point, then receive the response from the board.  This prevents you from performing digital operations at very high speed.  In general, I would say that 100 microseconds is a very good response using software-timed digital I/O on a Windows computer.
It is difficult to make a good recommendation without more detail about what you are trying to do.  You may need to consider switching to a Real-Time operating system, or upgrading your DAQ hardware to a board that will allow you to time your digital acquisitions on the board itself.  These devices, such as the m-Series DAQ or the PCI-653x series, would allow you to use hardware triggers for your digital acquisitions, change detection, and buffered data acquisitions to reduce the software overhead involved in a rapid acquisition.
(3,292 Views)
