Measurement Studio for VC++
how to reference to additional plot in cwgraph3d?
Hi everyone,
I am currently working on a project that will require an additional plot overlay on top of the original plot.  I have already added an additional plot (plot-2) in the property page. However, I'm having some difficulty as how to reference to this plot when I'm writing up the code.  I am currently referencing to the graphs by:
graph3d.Plot3DParametricSurface(xData,yData,zData,vOptional);
With this reference, I can only work with the first plot (plot-1).  Can someone inform me on how to access my plot-2?  Any help will be greatly appreciated.
Currently working with Visual Basic C++ .NET with CW 3D Graph 7.0.
Allen
Message Edited by alchan on 09-27-2005 12:52 PM
(4,555 Views)
sorry i meant visual studio c++ .net
(4,550 Views)
The CNiGraph3D plotting methods are short cuts to the plotting methods on the first CNiPlot3D object in the CNiGraph3D::Plots collection. To plot data to another CNiPlot3D, you must obtain a reference to it and call a plot method directly on it. You use the Item method on the Plots collection to obtain a reference to an object in the collection. You can pass either a name or a one-based index to the Item method. In your case, either of the following lines should do the trick:
graph3d.Plots.Item("plot-2").Plot3DParametricSurface(xData,yData,zData,vOptional);
graph3d.Plots.Item(2).Plot3DParametricSurface(xData,yData,zData,vOptional);
(4,537 Views)
hi
thanks very much for your reply,
For some reasons I don't have the Plots method or any of its associated methods avaliable in my cw3dgraph.h file.  I am currently using the generated .h and .cpp files automatically generated when I added the cw3dgraph activeX object into my dialog (MFC application), based on  cw3dgrph.ocx (current 7.0).  Very confused.......
I have attached my cw3dgraph.h and cw3dgraph.cpp file.
Thanks again.
Allen
(4,537 Views)
This is a known issue with ActiveX wrapper generation in Visual C++ 2002 and later and is not specific to Measurement Studio controls. The issue is that Visual C++ 2002 and later generate only the top level objects for ActiveX controls. The National Instruments support topic Why Are the Microsoft Visual C++ .NET-Generated Wrappers for Measurement Studio ActiveX Controls Inc... documents this issue.
Is there a reason that you don't want to use the C++ wrapper classes that Measurement Studio provides?
(4,531 Views)
hi drohacek
thats very much for the info.  sorry about the newbie question as my first timeprogramming with visual c .net.  i'm using the visual c++ feature installed with MS and they fixed all the problems.
Once again, thanks
(4,516 Views)
I'm glad to hear that this got you going with Measurement Studio. Good luck with your project(s).
(4,513 Views)
