Measurement Studio for VC++
how to save the value in Cedit control into a text file bu using measurement studio c++?
Im using measurement studio c++ to create a application. How to save a randomly generated value which display in the CNumberEdit Control to a text file? how to do the coding part?
(3,206 Views)
You can use the CNiFile class to write the value out to a file. For example, create a new Measurement Studio C++ project and follow these steps:
  1. Add a CNiNumEdit to the dialog.
  2. Add a member variable for the CNiNumEdit called m_numEdit.
  3. Add a button to the dialog.
  4. Double-click the button to add a message handler for the button's BN_CLICKED message.
  5. Add the following code to the button's BN_CLICKED message handler:
    CNiFile file("C:\\Values.log", CFile::modeCreate | CFile::modeWrite | CFile::typeText);
    file << m_numEdit.Value << endl;
    file.Close();
  6. Run the application, edit the CNiNumEdit's value, and click the button. The value should be written to the Values.log
    file as specified in the code above.
Hope this helps.
- Elton
(3,206 Views)
