Measurement Studio for VC++
how to take a single data point for each trigger pulse ( synchronous acquisition).
 hi
          im using the pci-mio-16E1 card, with the IDE VC++, so  im looking for an example to explicate me how to make an synchronous acquisition data using an external timing, so the idea is to acquire (take) a single data point for each trigger pulse  from one  input channel ,and saving  the data in a file .
now im making a code using the AI_setup and DAQ_op functions, im getting  a speed acquisition (it is the start of acquisition data), and  it is  a synchronous acquisition just for one trigger pulse, and me i looking for an acquisition for each trigger pulse.
  so to  understand my problem you can see my code :
iStatus = Timeout_Config(iDevice, lTimeout);
         iRetVal = NIDAQErrorHandler(iStatus, "Timeout_Config", iIgnoreWarning);
   //  configuration and selection of  signal trigger
         iStatus = Configure_HW_Analog_Trigger(iDevice, ND_ON, iLowValue,iHighValue, ND_ABOVE_HIGH_LEVEL, ND_THE_AI_CHANNEL);
        iRetVal = NIDAQErrorHandler(iStatus, "Configure_HW_Analog_Trigger", iIgnoreWarning);
  iStatus = Select_Signal(iDevice, ND_IN_CONVERT, ND_PFI_2,ND_HIGH_TO_LOW);
         iRetVal = NIDAQErrorHandler(iStatus, "Select_Signal", iIgnoreWarning);
    iStatus = AI_Setup(iDevice, iChannel, iGain);
   iRetVal = NIDAQErrorHandler(iStatus, "AI_Setup", iIgnoreWarning);
   while ((iReadingAvail != 1) && (iStatus == 0)) {
 /* Wait until reading is available. */
         iStatus = AI_Check(iDevice, &iReadingAvail, &iReading);
        iRetVal = NIDAQYield(iYieldON);
       //  Acquire data from a single channel
    iStatus = DAQ_Op (iDevice, iChannel, iGain, piBuffer, ulCount, dSampRate);
   while ((iDAQstopped != 1) && (iStatus == 0)) {
        iStatus = DAQ_Check(iDevice, &iDAQstopped, &ulRetrieved);
       iStatus = DAQ_VScale(iDevice, iChannel, iGain, dGainAdjust, dOffset,ulCount, piBuffer, pdVoltBuffer);
      iRetVal = NIDAQErrorHandler(iStatus, "DAQ_VScale",iIgnoreWarning);
   /* Set analog trigger mode back to initial state. */
       iStatus = Configure_HW_Analog_Trigger(iDevice, ND_OFF, iLowValue,iHighValue, ND_ABOVE_HIGH_LEVEL, ND_THE_AI_CHANNEL);
  /* Set PFI line back to initial state. */
       iStatus = Select_Signal(iDevice, ND_IN_START_TRIGGER,ND_AUTOMATIC, ND_DONT_CARE);
          iStatus = DAQ_Clear(iDevice);
 /* Plot acquired data  */
      iRetVal = NIDAQPlotWaveform(pdVoltBuffer,ulCount, WFM_DATA_F64);
so this is the data acquired -0.900879,-0.900879,-0.900879,-0.900879,-0.900879,-0.900879,-0.900879,-0.900879 and i think that is a noise because all time i get this data.
tank you very mutch fo your help
(3,197 Views)
Please see the responses to this thread at the following post.
Also, please only post one thread per issue.
Sean C.
(3,190 Views)
