05-08-2007 12:58 PM
05-16-2007 10:42 AM
Hi L_K,
I believe that you are correct in regards to using the SRQ line with Ethernet - I have not seen this combintation used before. From the excerpt of the user manual that you posted, I would have expected something like the OPC command to work - but clearly the task appears done before it truly is. Have you been able to use the OPC command successfully with any other command sequences? In general, this may be something that you will want to ask of the manufacturer of the signal generator as well, as they should have more information concerning the pattern loading process. Hopefully they would have some insight on how to determine when the process is complete. Hope this helps!
