Measurement Studio for VC++
initial state for CNiIIRCascadeFilterHi
I'm using a CNiIIRCascadeFilter for my signal processing.  I perform a forward an backward filtering on the data. To reduce transient on both ends I have to introcude paddings and to set the initial state of the filter. Is it possible to set the initial state? I could not find an appropriate method. Or is there a 'trick' to feed the filter with special values to achiev the wished state?
Thank you
 Mario
(6,385 Views)
Hi Mario!
I didn't found any 'trick' to in set an initial state. I didn't found anything else than that is documented in the MStudio help. For all methods of these classe please refer the help file.
ms-help://MS.VSCC.v80/MS.VSIPCC.v80/NI.MeasurementStudio.2005/NIVCAnalysis/Objects/CNiIIRCascadeFilter/Main.htm
Regards
Tobias Lange
(6,366 Views)
OK, when I'm talking about the initial state I do not mean the forward and backward coefficients. I mean the initial values of the internal states which are needed to calculate the output.
What I can do is formulate the filter as a system of equations and try to solve this system for the input values. May work....
(6,364 Views)
