Measurement Studio for VC++
linker error: can't open "ini.lib"
I've just installed the Evaluation copy of the Measurement Studio Tools for Visual C++ and whenever I try to run an example or a program that I create I get a linker error referencing ini.lib? I can find ini.lib in 2 folders both descending from VXIpnp, but I've also called the hotline and I was told I need the INI driver. Doesn't that come with the evaluation CD or do I need to manually download it from your website and then install it myself?
Alex
(3,823 Views)
You need to add the path of the ini.lib to the VC++ environment. The installer should have done this for you, but it must not have. Go to Tools->Options and under the directories tab, add a Library files entry that points to the ini.lib directory.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(3,823 Views)
