Measurement Studio for VC++
linking errors whlie running C examples of data acquisition using niScope and visual C++
hello,
I have an NI PXIe-1071 chassis with 2 PXI 5154 digitizer cards and NI PXIe 8102 controller.
I am trying to acquire data using the same. Right now I am trying to compile some of the C based examples given in the documentation of niScope. But I am unable to do so. for instance when I tried to run "ConfigureAcquisition.c ". I am having many errors like the one given below.
error LNK2019: unresolved external symbols _niScope_init@16 referenced in function _niScope_GenericConfiguredAcquisition@0
for every niScope based function used in the example it is showing the same error.
I have only 2 files niScope.h and niScope.lib. In niScope.h there are declarations for each function but their definition is not there and I came to know that I also require source file of the same to avoid the error. Is this true????
if I dont reqire source file please suggest me how to avoid such errors. and if I require source file from where I could find it as I talked with NI people and one of the application engineer told me that this is not available with them.
Please help me with the same.
regards
Sagar
Message 1 of 1
(5,260 Views)
