Measurement Studio for VC++
map<string,string> compile errors
Console app in VC7 on W2K
I'm trying to compile the following code. In the simple program below no
problem. In my real program ( a Windows Service) the insert method causes
compile errors. The compiler and linker flags seem to be the same in both
programs. Obviously there is some environment difference between my two
programs, but I can't see it. Any help would be appreciated.
kevin aubuchon
Compiler settings:
/O1 /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_MBCS" /FD /EHsc /ML /GS /Fx
/FAs /Fa"Release/" /Fo"Release/" /Fd"Release/vc70.pdb" /W3 /nologo /c /TP
Linker settings:
/OUT:"Release/service_one.exe" /INCREMENTAL:NO /NOLOGO /SUBSYSTEM:CONSOLE
/OPT:REF /OPT:ICF /MACHINE:X86 kernel32.lib user32.lib gdi32.lib
winspoo
l.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib
uuid.lib odbc32.lib odbccp32.lib
====Compile Time Errors=====
C:\Program Files\Microsoft Visual Studio .NET
2003\Vc7\include\functional(139): error C2676: binary '<' : 'const
std::string' does not define this operator or a conversion to a type
acceptable to the predefined operator
2003\Vc7\include\functional(139): error C2784: 'bool std::operator <(const
std::_Tree<_Traits> &,const std::_Tree<_Traits> &)' : could not deduce
template argument for 'const std::_Tree<_Traits> &' from 'const std::string'
#define _WIN32_WINNT 0x0400
#include "stdafx.h"
#include
#include
#include
#include
typedef std::map<:STRING> STRINGMAP_TYPE;
typedef STRINGMAP_TYPE::value_type ST_value_type;
int _tmain(int argc, _TCHAR* argv[])
return 0;
STRINGMAP_TYPE strings;
ST_value_type* pvt;
std::string key = "hello";
std::string ob
ject = "hello";
pvt = new ST_value_type(key,object);
strings.insert (*pvt);
(3,529 Views)
Hello Kevin,
Try this example.
I have found it on MSDN
I have rewritten from INT2STRING to STRING2STRING
It seems you have to ignore the warnings
Greetings
Juergen
(3,529 Views)
