Measurement Studio for VC++
member functions of CNiButton
How can I access the member functions of a CNiButton using Measuement studio?
I have tried the following:
//Header file
public:
 CNiButton *T1;
//implementation file
//OnInitDialog()
 T1=(CNiButton *) GetDlgItem(IDC_CWBOOLEAN1);
//ClickCwboolean1()
 bool flag=T1->GetValue();
Compiles ok.
When run & Boolean is clicked, Results in 'Unhandled Exception'
(6,313 Views)
Hi Mike,
You do not need to use the GetDlgItem command in your code. In your code you should have the expression DDX_Control(pDX, IDC_CWBOOLEAN1, T1); which already gets the value from the dialog. Without the GetDlgItem command, you also no longer need to use a pointer for T1. You can just use the GetValue function to access the member function. You can check out the project I have attached to see how this is done.
(6,276 Views)
