Measurement Studio for VC++
menu color
How do you change the background color of a menu?
(3,204 Views)
Sorry about the many menu questions....the internet was acting weird.
(3,204 Views)
Default menu colors are determined by system settings, so the easiest way would be to change the menu option in your system appearance properties. If you need to change this only in your application for some reason, you will need to owner-draw the menu. You can find tons of articles and examples about owner-drawn menus if you search on Google, and you may want to also take a look at the Microsoft Knowledge Base article OwnCombo.exe Demonstrates an Owner-Draw Combo Box for an example of how to customize various menu settings via owner-draw. Another article you might find interesting is MFC Self-Drawing Menus on MSDN. Once you understand how to owner-draw menus, you can customize anything you want on the menu, including the background color.
- Elton
(3,204 Views)
