Measurement Studio for VC++
need help to get started with USB-6229
I just bought NI USB-6229 multifunction DAQ.  What I want are 3 analog output voltage ( 0 - 5V ), and 3 digital output for swap relays. The labview program for this DAQ will be part of my acquisition program. Could anyone tell me some sample code for this kind of setting ? I just startded to use labview.  thanks.
(6,319 Views)
Hello mathink,
Welcome to the NI Discussion Forums!  There are a ton of great resources for programming with DAQmx.  First, I would recommend checking out the NI Example Finder.  This is located in LabVIEW under Help -> Find Examples.  This program automatically lists all of the installed examples for LabVIEW that are already built and included when you install LabVIEW and DAQmx.  If you navigate to the folder Hardware Input and Output -> DAQmx you can find a list of folders with all the DAQmx examples installed.  Each folder covers a specific subsystem of your DAQ device.
There are some great resources on learning LabVIEW.  Check out LabVIEW Introduction Course - Three Hours and LabVIEW Introduction Course - Six Hours
Also, the links in my signature are great for when you start programming with DAQmx and the wiring guides are great for if you ever have to post code on this forum.  I would also recommend for when you have a specific programming question, to feel free to post that question in the Multifunction DAQ boards.  Good luck on your applications!
Browning G
FlexRIO R&D
(6,295 Views)
