Measurement Studio for VC++
newbie, debug for VC++
first of all, i am a new dude to the vc++ debugger
I want to know if there is a way to trace the flow of a program which has
'void' within a program. for example, if i the program has a main() which
has many classes and functions.... will the degugger of vc++ directs me into
those functions and show me how the data are changed the moment the program
is ran? i know i can do a Step-Into or Step-Over to see the change, but
they only show the step in main(), not into the void and classes. could
someone be so kind to show me where i can find those information (or how it
can be done?) my demostrator has about thousands lines and it would be nice
to see the mechanism of it as a debug execise.
Thank you.
(3,133 Views)
You will need to "Step Into" your class ctor (short for constructor) or any of your class's member functions. If you are not instantiating an object of a particular class you want to debug, you will never get to any of it's code. If nothing I said there makes sense to you, you may want to check out some programming sites like www.codeproject.com for some basics on C++. Hope that helps.
(3,133 Views)
