Measurement Studio for VC++
nidaq redistributable?
(6,102 Views)
No, You still have to install the whole driver.
Regards
(6,096 Views)
This is somewhat accurate.  While you do need to install the driver, you don't need the full 1.3GB version.  For a build executable, you can use the NI-DAQmx Core version, which is 150 MB and contains everything a built executable needs.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(6,092 Views)
