Measurement Studio for VC++
nimath80d
I've just installed Measurement Studio.
In C:\Program Files\National Instruments\MeasurementStudioVS2005\VCNET\Examples\Application\FrequencyResponse
I use the example.
It gives the following error:
NiMath80D.lib(CurveFitting.obj) : error LNK2001: unresolved external symbol "public: int __thiscall NI::CniDemo::Access(void)" (?Access@CniDemo@NI@@QAEHXZ)
Which library do I put where and where do I get it?
When I try the project:
C:\Program Files\National Instruments\MeasurementStudioVS2005\VCNET\Examples\Application\SpectrumAnalyzer
c:\program files\national instruments\measurementstudiovs2005\vcnet\examples\application\spectrumanalyzer\niincludes.h(18) : fatal error C1083: Cannot open include file: 'NiDAQmxComponent.h': No such file or directory
That file is not on my disk.
Where do I get it and where do I put it?
You may put me in touch with your tester
Also,
(6,463 Views)
Hi, nimath80d,
Which version of Measurement Studio did you install? If you have the standard edition, it's not going to have the curve fitting library, which is required by that example.
For the second question, you need to download our DAQmx driver. You can find it here.
Song D
Song Du
Systems Software
National Instruments R&D
(6,445 Views)
