Measurement Studio for VC++
problem compiling example
I tried to compile an example from NI488.2 language interface "findinstruments" and it returns me this error message:
"  fatal error C1010: unexpected end of file while looking for precompiled header directive   "
what does it mean?
what am I doing wrong?
Leo
PS:
thanks to anyone can answer me!
(4,213 Views)
It is not quite clear what example you are trying to compile and also whether you are using VStudio 6.0 or .NET.
Anyways, I think you might get interesting info on the following page which deals with an error similar to what you are getting from your compiler.
AlessioD
(4,205 Views)
You have precompiled headers enabled.
In your Visual Studio project settings, under C/C++, select the precompiled header option to be "not using precompiled header".
Bilal Durrani
NI
(4,192 Views)
I Compiled and ran some examples. I succeded in controlling my instrument from the server machine but and I was trying to send some commands from my laptop computer (in the same subnet).
Anyone knows if I can find some type of c++ libraries that allow me to go on the network?
Leo.
(4,188 Views)
so,
are you willing to control an instrument that is attached to a computer over the network?
Is that instrument IEEE 488.2 compliant?
This TUTORIAL  explains how to program remote devices through NI-VISA. It does refer to LabVIEW programming, but it should not be that different if you use the NI-VISA C API.
AlessioD
(4,171 Views)
