Measurement Studio for VC++
problem upgrading usb AI 9215 to 6009
I am substituting a  6009 AI/AO/DO USB device for a 9215 AI/AO device, using NIDAQmx V1.4 and VC++ 6.0.   If I make no software changes, the 6009 operates as the 9215 did, giving four AI inputs.
If I increase the number of inputs to 8,  adjusting appropriate parameters, the attempt to create a channel returns error -200077.
Can you tell me what this error means, and what steps I should try to fix it?
 Thank you
    Phil Batson
(6,072 Views)
I needed to set the configuration to Referenced Single Ended to get more than 4 inputs.  I didn't realize that the default configuration would be differential.
(6,069 Views)
