Measurement Studio for VC++
problems using cwgraph
Hi.
I am developing a graphical user interface to display several parameters on different dialogs using Microsoft Visual C++ .NET.  Each of 5 dialogs have one CWgraph and they are all displaying data.  I retrieve a single x,y pair and then plot this using the chartxy() member function.  I have run into several problems while trying to add these measurement studio plots to my project and I was wondering if anyone else ran into anything like this.
1) Using the controls in a windowless mode caused the program to run slowly and kept displaying the message "Control tried to invalidate pixels outside its bounds" in the output window.
2) I tried to use windowed graphs and that caused the program to crash when I deleted the dialog box in which the graphs reside.
3) Finally I started not worrying about deleting the dialogs before exiting and just allowing the object dump.  In this windowed mode the program uses 100% of CPU time and runs very slowly.
I would appreciate any advice.  Thanks!
amig
(3,911 Views)
Are you using multiple threads in your application? If you do, make sure you call CoInitialize() before you call any function of the graph.
Do you have a sample I have a look at? Which version of Measurement Studio are you using?
Bilal Durrani
NI
(3,906 Views)
