Measurement Studio for VC++
recording wav file
HI is there any way to record wav file using Code composer studio to TI 5510 DSK and play them back. I am having problem writing a code to record in wav format. Plz help if there is any simple code to understand. Thank you
(3,736 Views)
akki20,
I think you are looking for Texas Instruments. That is, unless you are somehow interfacing the 5510 DSK with LabVIEW or are using Measurement Studio for display / control. Let us know if that is the case.
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,729 Views)
Just saw your other post... Unfortunately, LabVIEW DSP does not support the 5510 DSK.
Hope this helps,
Ryan Verret
Signal Generators
(3,726 Views)
