Measurement Studio for VC++
scan_op and scan_demux for NI 4472 board
how do I use scan_op and scan_demux for the 24bit 4472 board, since all of the buffers for the arguments are shorts with out losing data, due to the data size of the short arguments?
(2,958 Views)
To use the NI-DAQ functions with the 4472, you'll need to declare the samples buffer as a i32 array (array of 32-bit integers). The functions takes pointers to i16 arrays, so the pointer to the i32 array needs to be typecasted to an i16 pointer, for example:
static i32 piBuffer[1000] = {0};
iStatus = DAQ_Start(iDevice, iChan, iGain, (i16*) piBuffer, ulCount,
iSampTB, uSampInt);
The NI-DAQ driver will fill the array with the appropiate values.
Hope this helps. Let me know if you have any questions.
Diego Funes
(2,958 Views)
