Measurement Studio for VC++
second analog input scales wrong
I want to measure two channels at the same time with different voltage ranges:
DAQmxCreateAIVoltageChan(taskHandle,
                "Dev1/0","", DAQmx_Val_Cfg_Default,minVal0,maxVal0,DAQmx_Val_Volts,NULL);
                "Dev1/1","", DAQmx_Val_Cfg_Default,minVal1,maxVal1,DAQmx_Val_Volts,NULL);
when I read the results with DAQmxReadAnalogF64, the values of the second channel are scaled with the parameters of the first channel, for example:
channel0: [0 10]
channel1: [-0.1 0.1]
then the values from channel1 are between 0 and 10 instead of -0.1 and 0.1. Can someone help me?
(4,806 Views)
Hello!
Which DAQ hardware do you use?
Wolfgang
(4,787 Views)
I have a NI PCI-5122 (14 Bit 100MS/s Digitizer) and I installed the DAQmx 8.1 software
thanks,
Deran
(4,783 Views)
Hello Deran!
The PCI-5122 is a Digitizer. For this Digitizer you should install NI-SCOPE.
NI-SCOPE 3.1 installs NI-DAQ 8.1, IVI Compliance Package 2.3, NI-VISA 3.6, among other software (see readme.htm for more info).
http://digital.ni.com/softlib.nsf/websearch/C0489666CE6F58468625719500636C2C?opendocument&node=132060_US
If you have installed NI-SCOPE you should use the the NI-SCOPE library.
Examples and Documentation you can find after the installation of NI-SCOPE at
Start >> All Programs >> National Instruments >> NI-SCOPE
and here
http://digital.ni.com/manuals.nsf/websearch/44EEAE2AD6F15D2086256EEC006942E3?opendocument
http://zone.ni.com/devzone/conceptd.nsf/webmain/EF50F1961863583D862568DB00683667?opendocument
http://zone.ni.com/devzone/devzone.nsf/webcategories/47B945D23E10244F8625678600592F72
Wolfgang
(4,773 Views)
