Measurement Studio for VC++
signal routing on PCI-6602
What is the function I have to use like CNiDAQmxConnectTerms to rout two channel of my board?
Because this function is not recognize by the debugger.
That I want to do is to connect a PFI to the output the counter 0 or of the output counter 1 depending of a configuration that can change.
Thank you for your help,
(6,139 Views)
Hi Aurelien,
Thanks for posting on National Instruments forum.
I don't really understand what you want to say with "this function is not recognized by the debugger". May you tell me precisely what you want to do and the problem you observed?
Jérémy M. | LinkedIn - Contact
Don't forget to give Kudos to good answers.
(6,092 Views)
