Measurement Studio for VC++
%,; signifier problem with LabVIEW 8.5.1
Good afternoon,
I wrote a software under LV 8.2 which uses format code to customize display with , or . decimal point. So I use the following format : %,;%.3f or %.;%.3f depending on user settings.
When I convert the software under LV 8.5, using those format produce errors. I cannot format my display any more. The problem remains also when a new VI is build under LV 8.5 (without converting).
I attached a test VI to this post to illustrate what I mean. The VI is written under LV8.2 and works well. Under LV8.5 you will have an errror.
Knows anybody a solution to that problem?
Thanks in advance.
Adelina
(6,432 Views)
Sorry, but I think this post is not in the correct thread... I will put it better in the LabVIEW one!
Adelina
(6,424 Views)
Continued here.
(6,418 Views)
