Measurement Studio for VC++
simultaneous Analog In and Analog Out
How to Output on Analog Out and read Analog In at the same time.
I am using a VC++, NIDAQ 7.01.
No LabView.
(3,504 Views)
Greetings,
The following example demonstrates how to perform synchronized analog input and analog output:
Synchronizing Analog Input and Output
The example was written in CVI, but modifying it for use in VC++ is fairly straightforward and documented within the code.
Good luck with your application.
Spencer S.
(3,504 Views)
Thanks Specer...
I think it should work with PCI 6013. I will test it and if i have a problem, I will let you know.
regards
sumits
(3,504 Views)
