Measurement Studio for VC++
simultaneous waveform output NI-6731
How can I output waveforms on two AO channels, say DAC0OUT and DAC1OUT simultaneously? I am using Visual C++ and have been using the WFM_Op(..) function to output one signal on one AO channel. The other signal should be the same signal as on DAC0OUT but with a phase shift of 90 degrees.
I read at this discussion forum that I can combine the two signals in one buffer, and output, say, value 1 on DAQ0OUT and value 2 on DAQ1OUT and value 3 on DAQ0OUT again.. Is this possible with the NI6731?
(2,944 Views)
Please take a look at the following link and see the last example under LabWINDOWs/CVI section. The code you use will be similar in Visual C++ since it is also a C file only.
Link
In the WFM_Op, for multiple channels, you have to provide an array.
Please do let me know if the link helps.
Sincerely,
Sastry V
(2,944 Views)
