Measurement Studio for VC++
test of trigger during acquisition
During my acquisition, i need to test the trigger if it's correct to go on the acquisition.
Can i reset my trigger or other because i tried to stop and restart the task but it work but don't work like i want (i work with a system with a clock to 1.25MHz).
I have a NI PCI-6533 (DIO-32HS).
(6,829 Views)
I'm sorry but I don't understand what to you want to do. What is your configuration? The trigger is use to synchronize an input or ouput? Why you need to "reset" your trigger?
Can you tell us moreabout your project?
(6,813 Views)
I want to reset the trigger because if it turn off during my acquisition, i must stop the acquisition and if i don't test its, i don't know if it trun on or turn off and don't stop the acquisition.
Do you understand what i want to do?
(6,792 Views)
I'm sorry for the long responding time. If you want to reconfigure your task on the fly, you need to stop and restart your task. If the trigger happen and you want to rearm it, you need to use the function "DAQmxSetStartTrigRetriggerable", it's able to set multiple trigger.
(6,724 Views)
