Measurement Studio for VC++
unresolved external "niScope_init" referenced from "path"
First of all I'm sorry about my English. I'm developing a software on Builder C++ by Borland and we bought an NI DAQ 5112 PCI. I'd like to know if it's possible to use the high-level functions from niScope (such as niScope_init, _AutoSetup, _close...) on this plataform. I'm asking it 'cause I could run every example program on it whithout any problem.
(5,171 Views)
Hello Ceara,
Any C based environment could be used with the NI SCOPE functions to control your PCI 5112. The NI High-Speed Digitizers Help file has the NI-SCOPE Function Reference Help that lists all the C functions that could be used. Please let me know if you have any further questions.
Ayman K
(5,150 Views)
   Hi Ayman K, thanks for your help.
I bought this digitalizer which brings some examples in Visual C++ based. Fortunetly, there is a tool on Builder C++ (software that I use) that converts a VC++ project in a BC++ project. When i did it with each example code, it really worked (it run perfectly as a BC++ project), of course I needed to add the NISCOPE include and library directories to my project. My problem is that when I try to use this functions (such as niScope_init, niScope_ConfigureVertical, etc...), all of them high-level functions, into my own project, a message like these below is shown:
[Linker Error] Unresolved external 'niScope_init' referenced from C:\ALUNOS\ALLAN\EVA\BUILDER2.0C\UNIT1.OBJ
[Linker Error] Unresolved external 'niScope_AutoSetup' referenced from C:\ALUNOS\ALLAN\EVA\BUILDER2.0C\UNIT1.OBJ
[Linker Error] Unresolved external 'niScope_ConfigureVertical' referenced from C:\ALUNOS\ALLAN\EVA\BUILDER2.0C\UNIT1.OBJ
and so on
I already tried to add every include and/or library path from the example projects (that works) to my project, but it haven't worked. Now I'm looking for someone who have gotten some trouble like this. I even don't know if I'm looking it on the right way but I hope so. I aprecciate every help ok?
    Thanks a lot
              Allan Rocha
(5,144 Views)
Hi Allan,
Can you please post the borland project you are having problem with? Also, what version of Borland C++ compiler you are using?
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
(5,115 Views)
Hi Kalyanramu,
I just need your email adress to send it for you
Allan Rocha
(5,065 Views)
Hi Allan,
You can send e-mail to support@ni.com with Attention to my name and I will take ownership of that issue as it is linked with this discussion forum post.
Kalyan
(5,004 Views)
Hi, Kalyan
I'd like to say that I've resolved this problem myself but I don't think my solution is the best one. I'm going to explain it to you and if you have
some other idea, some better idea, please let me know. I changed an especific line of my "BCBProject file" who talks about the linker
like the following:
BEFORE:
  <LINKER>
    <ALLOBJ value="c0w32.obj $(PACKAGES) Memmgr.Lib sysinit.obj
$(OBJFILES)"/>
    <ALLRES value="$(RESFILES)"/>
    <ALLLIB value="$(LIBFILES) $(LIBRARIES) import32.lib cp32mti.lib"/>
    <OTHERFILES value=""/>
  </LINKER>
AFTER:
  <LINKER>
$(OBJFILES)"/>
    <ALLLIB value="$(LIBFILES) $(LIBRARIES) ODBCCP32.LIB UUID.LIB
NISCOPE.LIB
  </LINKER>
In different words, I just included the names of some libraries like in all "Example programs" from NI. Indeed I think there is another classic
way to say to the compiler that it is necessary to compile these libraries but while I don't discover it... My way works! Thank godness!
I apreciate your help dear friend.
Have a nice day!
(4,992 Views)
