Measurement Studio for VC++
usb4000 read spectra convert to waveform
I am working with a usb4000 ocean optics device and I wanted to acquire a set of 10 spectra and determine the average before outputting it to a graph display. So far I have been using the 'read spectra' for the usb4000, averaging all the scans in a loop and simply attempting to output it to a waveform chart. But if I do this my resulting spectrum on the graph does not look accurate.
I've attached my file here.
Any help would be much appreciated and please let me know if I need to clarify anything!
AK
(6,918 Views)
Take a look at these example, and how they take average.
https://decibel.ni.com/content/docs/DOC-12597
https://decibel.ni.com/content/docs/DOC-16840
(6,904 Views)
I don't think the problem has to do with the averaging of the values. I'm more confused about outputting data to a graph. For example there is a "Read spectral waveform" vi which when connected to a "spectral waveform graph" vi outputs the result just fine and I see the spectra on the graph.
However in my case, I would like to use the "Read spectra" vi to simply read in a number of spectra data points, and average them across multiple readings THEN display it on a "spectral waveform graph". However I am not sure of how saved data points are typically transmitted to be displayed on a graph wheras the previous vi "read spectral waveform" appears to already do the appropriate conversions for it to display on the graph?
I hope this makes my query more clear.
Thanks!
(6,896 Views)
Never mind I have figured out my mistake!
Thanks anyway for your help.
(6,893 Views)
Nice to hear, good luck.
(6,880 Views)
The Wrapper library contains most of the basic spectrometer control functions. You should only use the functions/VIs belonging to the Wrapper library object. These functions comprise the Wrapper API. The only time you may use functions/VIs outside of the Wrapper is if one of the wrapper VIs itself returns an object of a different type.
(5,990 Views)
