Measurement Studio for VC++
using value pairs with graph3d axsis labels
anybody using value pairs with version 1.0 of measurement studio for VC++(v6.0) ?
I have a app that uses value pairs on a graph3d - for one of the axis, the graph warpper class, NiAxis3D, does not seem to have any methods to disable the axis labels, so for example if set max-min is called with 0, 50, and a set of value pairs defined and asigned, to one of the axis (Z) then it seems to display both the value pair values, and the scale labels between 0 and 50 - it seems like a bug in the control! I've seen examples for useing value pairs with sliders and controls but none for the 3d graph!
any comments welcome!
regs
(3,013 Views)
Have you tried changing the color of the label to the background color? may not be the best, but I would probably work.
I'll try to do this in MStudio 6 to see if it is possible to hide the labels.
I'll let you know what I can find.
Juan Carlos
(3,013 Views)
