Measurement Studio for VC++
when autoscaled or when data inputted function
Is there any function that is called when CNiGraph is autoscaled or plotted?
i am using MFC dialog-based....
I would appreciate for any advice...
(3,298 Views)
Hi codeKin,
Can you give us some more information on what your end goal is with this? It sounds like you want to execute some code when a new plot is added to your graph.
There is a method for the CNiGraph control called OnCWBindingDataUpdated() that is executed when new data is added (plotted) to your graph. Also, you can check the CNiBindings.DataUpdated property to see if new data has been added.
There are a host of other CNiGraph Events as well, however most of them are a response to user interaction, such as a mouse click.
Let us know if this isnt' what you are looking for, and we can try to find a way to do what you are trying to do.
Thanks codeKin, have a good one.
Dan Weiland
Dan Weiland
(3,290 Views)
