Measurement Studio for VC++
while I'm doing image Processing in C++ using sampling file (HLGlab), the shown image is suddenly shut down.
when I run hlgrab.c  (c#Program File #National Instrumensts #NI-IMAQ #Sample #MSVC #Grab #HL Grab),
it naturally works good. However if I put image processing code between  errchk & (implot), visible window (result of image processing)
stop after 50~60 second.
I try to find the reasion to stop running, but I cannot find yet~!
Is there anyone to help me????
(7,067 Views)
Hello Superstar~!,
I looked for the example you mentioned, and after reading this KnowledgeBase article I discovered that the examples are now stored in [root]:\Documents and Settings\All Users\Documents\National Instruments\NI-IMAQ\Examples\MSVC\Grab\HL Grab.
Could you post your code to this forum for us to explore? This would help us to see what you are describing.
David G
Sales Engineer - SE Michigan & N Ohio
(7,041 Views)
Dear David G
Thank you for your kindness~!!
But I don't want to open the source on this reply board~!
So, I want to give you the source by email, could you give me your email address??
(7,025 Views)
Hey Superstar~!,
Please eliminate any proprietary or confidential information from your code by simplifying it. Once it is simple enough to demonstrate the problem, please post it to this forum so that all of the active forum posters have a chance to look at it.
You never know, often the simplifying step reveals the issue :)
David G
(7,012 Views)
