Measurement Studio for VC++
while uninstalling a setup created through InstallShield 10.5 evaluation version , the setup entry is not deleted from the Add Remove Programs of the control panel
hi,
i have created a setup using InstallShield 10.5 evaluation version , my setup is working fine but the problem is when i try to uninstall it from the Add Remove Programs of the control pannel its entry is not getting deleted from the Add Remove Programs of the Control Pannel , i manually have to delete the product key from the registry in order to delete its entry from the add remove programs of the control pannel , kindly help me in geting rid off this situation. i am using Windows XP as the Operating System.
Regards
Davinder
(3,532 Views)
HI Davider,
I was wondering how this issue pertains to Measurement Studio. The message board is for applications using National Instruments Measurement Studio software and Visual C++ 6.0. So if it does quite pertain, you might not have much luck here. I haven't used InstallShield 10.1 so I am not sure why you're seeing this problem.
SijinK
(3,520 Views)
