Measurement Studio for VC++
why a continuous acquisition will stops
I have download a continuous acquisition program from NI and use PCI-MIO-16E-4 card to tested this program. when choice the sample rate to 10000, if choice the samples less than 100, the acquisition will stop after while. Does anyone known why and have a solution? The buffer of CWAI control was "use default buffer size".
(2,984 Views)
You are running into buffer overflaw errors; one way to fix this is to increase the buffer size, and/or the number of samples.
RamziH.
(2,984 Views)
