Measurement Studio for VC++
why there's run time error while I'm using CWAI's start() and configure() in a worker thread of a dialog?
Below is part of my codes:
UINT ThermocoupleReadTemp(LPVOID pParam)
P3Dlg* pDlg = (P3Dlg*)pParam;
double AcquireRate;
int NumOfScan;
COleVariant upper = 0.01;
COleVariant lower = -0.01;
COleVariant vOptional((long) DISP_E_PARAMNOTFOUND, VT_ERROR);
CString channels;
CString temp;
pDlg->measureCJTemp();
temp.Format("CJTemp = %f",double(pDlg->getCJTemp()));
AfxMessageBox(temp, MB_OK | MB_ICONERROR);
AcquireRate = double(pDlg->getThermocoupleRate());
NumOfScan = 3;
pDlg->findMinMaxCh();
channels.Format("ob0!sc1!md1!%d:%d",pDlg->getMinCh(),pDlg->getMaxCh());
pDlg->getCWAI()->SetDevice(1);
pDlg->getCWAI()->GetChannels().Remo
veAll();
pDlg->getCWAI()->GetChannels().Add(channels,upper,lower,vOptional,vOptional);
//this SetNScans cause the graph to stop when dragging the window
pDlg->getCWAI()->SetNScans(NumOfScan);
pDlg->getCWAI()->GetScanClock().SetFrequency(AcquireRate * NumOfScan);
pDlg->getCWAI()->GetStopCondition().SetType(cwaiContinuous);
checker(pDlg->getCWAI()->Configure(),1); //problem!!!
checker(pDlg->getCWAI()->Start(),2);
return 0;
this is the function run in a worker thread, but I get run time errpr with that, the problem is with the configure() and start(). Can somebody tell me why? Thanks. By the way, I also wondering how to put the "return 0;" things, cos it can't run the start(), then end thread itself..
(3,351 Views)
Have you tried running your code from a single main thread? This would be a good technique for narrowing the issue you are experiencing, eliminating your settings from the threading issue.
You might also try just scanning one channel. Lets narrow the issue a little more to decide where to start.
(3,351 Views)
I have tried in a main thread, there's no prob at all, I've also tried with single channel, it just gave me runtime error.. sigh..
I now give it up and try to use lower level language to implement the thermocouple reading, got any idea how to do it without using CWAI?
(3,351 Views)
Check your other post for solution:
http://exchange.ni.com/servlet/Redirect?id=9045342
(3,351 Views)
