12-07-2005 03:59 PM
12-08-2005
11:51 AM
- last edited on
03-02-2026
12:16 PM
by
Content Cleaner
Hi eyeman-
The ~400MB version of NI-DAQmx is the only build available for any O/S. XP Embedded is not officially supported by the driver, but it sounds like your app is working reasonably well anyway.
If you absolutely can't live with the size of the NI-DAQmx driver you may consider developing your own using the MHDDK. This definitely isn't the easiest option, but it would allow you to pare down the footprint of your driver considerably.
