Michigan LabVIEW User Group
SharedVariableReplacement_updated.zip
Object-Oriented Design Patterns for Distributed Systems (Shared variable replacement)
Here is an amplified copy of my presentation slides and rough prototype code.
Jordan McBain, PhD
LabVIEW Controls Engineer
Revolutionary Engineering
(6,800 Views)
Thanks so much for giving this presentation!
Dan Shangraw, P.E.
(5,056 Views)
I'll be presenting a significantly expanded version of this presentation at NI Week:
https://niweek2015.lanyonevents.com/connect/sessionDetail.ww?SESSION_ID=6157&tclass=popup#.VbqqzC0M5...
I will eventually get around to creating a "design pattern page" on NI's forums with the code made available - so if you can't attend, you can at least see what I did.
Jordan McBain, PhD
(5,056 Views)
