Milwaukee LabVIEW Community
Certified LabView Developer
Key Duties, Responsibility, and Overview of person & Role
• Ideal candidate will have a very strong understanding of LabView including advanced-level coding, as well as a thorough understanding of all capabilities
• Will be comfortable working in a team environment where there is not a ‘cube farm,’ but a room with 3- 5 employee’s working in a collaborative environment – candidate should have the ability & confidence level to make suggestions and/or recommendations on the project.
PLUS:
• Client uses a Software program called: CRIO – any experience with this software is great
• Preferably, candidate will have experience with Real-Time Software Development/ Applications
• Any experience with ‘FPGA Layer’ as it relates to LabView/ coding will be very helpful as this will help to move project forward, and if an individual does know about FPGA, they will be able to provide direction to the group in how to best utilize this technology
• Candidate will go through all existing (Prototype-Level) code to make sure code is accurate, and will make assessments on the existing code, and will also help with creating ‘optimal’ code for putting into Production, Manufacturing, and ultimately, the Field
• Any experience with off-highway/ off-road, rugged field applications, Robotics, mobile applications, or anything related) – this will help them understand the project well
• Knowledge of Progression Testing, Production Intent, or any testing is strongly desired, however, not 100% mandatory in this role, however, there will be testing involved
Testing (Software):
• Will need to test all coding to ensure this will be a ‘set it and forget it’ code, meaning there should be very little maintenance and/or client interaction moving forward as the code/ product needs to be correct ‘right off the bat,’ so ensuring this through testing is very important
• Ideal candidate will be comfortable not having ‘everything’ defined regarding the position and duties, and will be motivated and self-directed in assisting where the project needs to be
• 90% of position will be LabView-related – whether testing, collaborating, or performing other duties – so person MUST be very proficient and a ‘high-level’ LabView Developer
This is a contract position with an hourly wage of $40 – 48/Hr DOE.Calvin Patrick
Technical Recruiter
Key Technical Solutions
10400 Innovation Drive, Suite 301
Wauwatosa, WI 53226
Website:  www.itskey.com
Fax:  (414) 302 – 5005
Message 1 of 1
(4,073 Views)
