Montreal/Quebec LabVIEW User Group Community - QLUG
MAX CRIO9038 device located but no options
I have a CRIO 9038. I have installed the NI software and drivers as best I could according to the official instructions. When I connect my device to my computer, it gets detected by NI MAX, however, when I select it under Devices and Interfaces, there are no options to Self test, test panels or anything.
My goal is to eventually have it working with nidaqmx-python , however, at this point, the device is not getting listed when using nidaqmx-python to list connected devices.
I have been stuck on this for a very long time. I don't know know what I'm doing wrong. Any help would be greatly appreciated. Thanks in advance.
I have tried various versions of NI MAX, including latest 2022 version, 2014, and now 2016 version, all have this same issue. I have also installed.
I am on Windows 10. (Also tested on 11, same issue)
(1,455 Views)
If you are still looking for a solution....
The 903x does support DAQmx but that is to interact with the C Series IO modules on the RT controller.
It won't work in MAX like a traditional DAQmx device.
The cRIO has a Real-Time Controller that you target by having the LabVIEW Real-Time module installed on your development machine. and the NI CompactRIO driver.
As a starting point with CompactRIO, go through this online training: https://learn.ni.com/learn/article/getting-started-with-compactrio-hardware-and-labview
Vincent Carpentier, Ing./Eng.
CLA, CPI
Neosoft Technologies
www.neosoft.ca
DQMH Trusted Advisor
(443 Views)
