3 phase 230 V motor control
Hi i'm new to the controls with Labview but i'm searching a way to easily control a 3 Phase motor ( 3 x 230 V ) which needs to be speed regulated ( frequention ) and also be switched from back to forth and otherwise ( fase 1 and 2 need to be switched for that ) is there a module that can do this for me?
regards
Nand
VUmc VU Medical Centre
(5,750 Views)
Yes, it is called a Variable Frequency Drive or Inverter.  Available in all grades and sizes from a variety of suppliers.  I prefer ABB.  Can be controlled with digital I/O(start, stop, direction and analog for speed), or over a comms bus(most common is Modbus).
(5,734 Views)
Hello Nand,
Do you have any other specifications concerning the 3 Phase Motor you're using?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,680 Views)
